NeilF Posted February 26, 2008 Share Posted February 26, 2008 I'm looking for suggestions on how and where (with the least effort!) to lead a microphone wire from behind the stereo head unit to the outside, probably around the area of the instrument binnacle or the A post Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 26, 2008 Share Posted February 26, 2008 Where are you trying to end up with the mic located? The instrument binnacle, A post and headlining would be the route i Would use Quote Link to comment Share on other sites More sharing options...
NeilF Posted February 26, 2008 Author Share Posted February 26, 2008 Where are you trying to end up with the mic located?The instrument binnacle, A post and headlining would be the route i Would use Yes my first thought was to exit via the binnacle - even placing the mic around here would be ok. I note that the binnacle is only held on with two screws, but hidden behind the steering wheel - how do you get at them? How is the covering to the A post attached? easy to get off? Quote Link to comment Share on other sites More sharing options...
sotal Posted February 26, 2008 Share Posted February 26, 2008 Do you mean it's just a handsfree mic? And you want to get it up to the sunvisor or somewhere like that? Your first post made it sound like you were trying to get it outside the car Quote Link to comment Share on other sites More sharing options...
NeilF Posted February 26, 2008 Author Share Posted February 26, 2008 Do you mean it's just a handsfree mic? And you want to get it up to the sunvisor or somewhere like that? Your first post made it sound like you were trying to get it outside the car Yes, sorry I was so imprecise - I just want to exit the mic wire from the back of the radio in the simplest way possible. I know it's probably rather trivial, but my usual experience of removing plastic trim is by the time I've worked out how it's supposed to come off, I've already broken it... Quote Link to comment Share on other sites More sharing options...
