Monster Posted March 16, 2008 Share Posted March 16, 2008 Hi Guys, As you may have gathered i am embarking on a discovery 200tdi/LT77/R380 transplant. I plan to use the 200 discovery engine mounts, as opposed to the usual 90/110 4cyl mounts. I realise that the 4cyl would be easier but i am hoping that by using the discovery mounts it would reduce vibration! Any one got access to a discovery chassis with no engine so as to take a pic? Les seems to think that the 200 mounts are slightly different to 300. Maybe i could go the whole hog and fit 300 engine mounts? Maybe i should add a link to the discovery or wanted forum. How do i do that?? Any thoughts? Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2008 Share Posted March 16, 2008 Disco 200Tdi mounts & Defender 300Tdi mounts are completly different, I don't think you'd notice any less vibration by using the Disco mounts, use the esixting mounts & not worry about altering the chassis welded on part of the mount. just add a post into the wanted forum like you have here multi posting in 2 or more forums is frowned upon, so please don't Quote Link to comment Share on other sites More sharing options...
Monster Posted March 16, 2008 Author Share Posted March 16, 2008 Disco 200Tdi mounts & Defender 300Tdi mounts are completly different, I don't think you'd notice any less vibration by using the Disco mounts, use the esixting mounts & not worry about altering the chassis welded on part of the mount. just add a post into the wanted forum like you have here multi posting in 2 or more forums is frowned upon, so please don't Hi, I take your point. My chassis is galvanised also. But on idle the engine, on 4cyl mounts, vibration is a bit hard to bear. I am removing a V8 on an auto box. Do you think that i could use the original V8 engine mounts? I know that there are a few positions that the 4cyl engine mounts could be bolted on to the 200 engine. If not, i would probably have to move/remove them anyways. Your thoughts, Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2008 Share Posted March 16, 2008 reusing the V8 mounts depends on where the engine/gearbox is going to fit in relation to the existing mounts, not having owned a Disco of any description, I hesitate to say if it'lll sit in the right place. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted March 16, 2008 Share Posted March 16, 2008 Hi Monster I fitted my 200 engine using discovery mounts, there should be pics on my write up on here some where. I cut the old brackets off the disco chassis but they would be simple to make. Im not sure how much vibration they cut down as I have V8 mounts on the gear box but they do make engine removal a simple opperation. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted March 16, 2008 Share Posted March 16, 2008 a pic of my mounts to put a disco 200 tdi on to a V8 R380, the engine ends uo forward like a 300 TDI. Quote Link to comment Share on other sites More sharing options...
