Gizzard Puke Posted March 17, 2008 Share Posted March 17, 2008 Hi all, Will a 235/85/16 tyre go on a 1997 discovery with out any problems ? Im running 235/70/16s at the moment. Cheers all, Trev Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 18, 2008 Share Posted March 18, 2008 If you do a search the subject has been covered 100 times before... The short answer is no if you are looking for a straight fit. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted March 18, 2008 Share Posted March 18, 2008 As the esteemed Bogmonster says do a search. They won't fit straight on you will have to trim the wheel arches (camel cut) and adjust the lock stops. Pete. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 18, 2008 Share Posted March 18, 2008 And, again, here is the url for the tire size calculator. It will soon show you the difference http://www.miata.net/garage/tirecalc.html Quote Link to comment Share on other sites More sharing options...
