Does an early 90/110 transfer box fit a ZF auto on a Rangie?
The LT230 and ZF 4 speed were standard fit '86 to '89 ish, with the 3.5efi, so you shouldn't have any trouble.
I'm not sure what the ratio in the RR LT230 was, not sure if any studs/bolts need moving/omitting, i've never split the LT230/ZF pair i have sat in the rangie.
Edit: I really should stop making cups of coffee whilst posting :blush:
It depends whether you mean lower or low ratio. a defender lt230 has a ratio of 1:4 so will be lower than your range rovers 1:2 however the low ratio lt230 is from early 90's and 110's and comes in 1:6 flavour, either will fit its just chooseing which ratio you want.
Will.
