Spill return assembly
Afternoon all,
A while back I had a problem with the spill return banjos on the injectors working loose and throwing diesel about the place. Replacing the copper washers worked for a while but the problem is back :angry:
The pipe assembly puts strain on the banjos eventually loosening them.
I remember reading a while back that the pipe assembly was changed. Is this true?
If so, I want to change to the later type.
The only part no I can find is ERR3652. Is this early or late? Anyone have a part number for the redesigned type?
Cheers muchly!
Yep ERR3652 is the later spill return line with the short sections of rubber hose used on Defender 200Tdi & Discovery 200Tdi from chassis number KA045370 :D
you can see mine in this photo.
Perfect, thanks Ralph. I reckon that should do the trick. :)
Sorry to hear of your t-box woes :(
