vinny Posted March 27, 2008 Share Posted March 27, 2008 Fitted an old RRC rear axle to my 90 a few years back. The A frame ball joint keeps loosening where it joins the axle. Ive had to tighten the castle nut a few times and refit the split pin but it keeps comming loose. I fitted a new ball joint but the problem persists. I think the tapered hole has become oval and allows the joint to move. Has anybody a solution to this problem? New casing?? Quote Link to comment Share on other sites More sharing options...
Scotian Posted March 27, 2008 Share Posted March 27, 2008 have you tried a bit of thread lock? Super glue will do the job. Quote Link to comment Share on other sites More sharing options...
vinny Posted March 27, 2008 Author Share Posted March 27, 2008 Dont think the nuts comming loose Its a castle nut and split pin arrangement! Or do you mean to use it on the tapered sholder? Quote Link to comment Share on other sites More sharing options...
paintman Posted March 27, 2008 Share Posted March 27, 2008 If the nut appears loose - and as you say, if it has a split pin lock then the nut isn't backing off - it sounds like either the tapered hole is very worn or it is cracked & the taper pin is opening it up. You could cut it off & weld a good one on in its place if you don't want to replace the whole casing. Quote Link to comment Share on other sites More sharing options...
vinny Posted March 27, 2008 Author Share Posted March 27, 2008 If the nut appears loose - and as you say, if it has a split pin lock then the nut isn't backing off - it sounds like either the tapered hole is very worn or it is cracked & the taper pin is opening it up.You could cut it off & weld a good one on in its place if you don't want to replace the whole casing. Why didnt I think of that I think thats the way to go rather than changing the casing/axle Cheers Paintman Quote Link to comment Share on other sites More sharing options...
