newclear Posted March 30, 2008 Share Posted March 30, 2008 Hi all, Writing this I almost feel like I should know it, sure I've seen the answer somewhere and I thought it was on here, but the search didn't bring anything up and I can't see it in the Tech Archive... Spent the past hour looking, can already see the first single post being a link to the exact answer I'm in in the middle of removing my old 2.5n/a Diesel out of my 1986 90 and replacing it with a 300tdi out of a Discovery. Upon removing the 2.5n/a looking at the two Flywheels, the "current" 2.5n/a one looks better than the one on the 300tdi, better in terms of wear... Can these two flywheels be swapped, are there any issues in doing so? Like Amount of teeth on the Gear Ring/position of mounting bolts or Clutch locating dowels... Any help would be great, feel sort of stupid asking though Cheers Matt2 Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 30, 2008 Share Posted March 30, 2008 Looking on microcat, 200's & 300's share the same number, the 2.5NA's are a different one, but, if they look the same, i'd go for it! Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2008 Share Posted March 30, 2008 Done a bit of searching in EPC, it tells me this 2.5n/a diesel has ring gear part number 568431 upto chassis number MA962814 & the same part from chassis number MA962815 now the good news for you Discovery 300Tdi uses the same ring gear LR part number 568431 Quote Link to comment Share on other sites More sharing options...
newclear Posted March 30, 2008 Author Share Posted March 30, 2008 Well, looking at the two engines out of the truck, they do indeed look the same. Going to take them both off and look at them closer... Just need the engine mounts Cheers Matt2 Quote Link to comment Share on other sites More sharing options...
