MECCANO Posted March 31, 2008 Share Posted March 31, 2008 I've got a 300tdi rocker shaft, that has had the springs that keep the rockers in position distorted during transit. How do I separate the "blocks" on the ends from the shaft? Is it just a case of gentle persuasion??? They seem pretty firmly fixed on! Cheers In advance Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 31, 2008 Share Posted March 31, 2008 They are sweated on, so carefully tap them down the shaft until they come off. No need to remove the centre one obviously, and bear in mind there are two 'shapes' of rocker and washers that prevent the springs from digging into the pillars. To refit the the pillars, just warm them up and they slide on very easily. Not that I did all this just recently you understand! And so-on. I'm sure you can see the pattern The shaft itself only wears on one side and I'm prettycertainalmostdefinitelyperhapsitwill - turn 180-deg to restore that 'straight from the factory' condition Les Quote Link to comment Share on other sites More sharing options...
MECCANO Posted April 1, 2008 Author Share Posted April 1, 2008 Excellent, cheers muchly !!! Quote Link to comment Share on other sites More sharing options...
