headdamage Posted April 4, 2008 Share Posted April 4, 2008 I've stripped a disco 200tdi that was in a defender and found that the four ladder frame bolts that come through from the flywheel housing where missing. Do I have to replace these or can I leave them out so that the ladder fram can be removed with the engine insitu at a later date? In short do they need to be there? Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2008 Share Posted April 4, 2008 I'd put them in, less chance of oil leaks & the ladder frame distorting, if they didn't need to be there then I doubt the engine designers would have fitted them. parts book shows 6 bolts 2 off M8 x 125mm flanged hex head part number FB108251 & 4 off M8 x 60mm flanged hex head part number FB108121L Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 5, 2008 Share Posted April 5, 2008 I've stripped a disco 200tdi that was in a defender and found that the four ladder frame bolts that come through from the flywheel housing where missing. Do I have to replace these or can I leave them out so that the ladder fram can be removed with the engine insitu at a later date? In short do they need to be there? They wouldnt have been fitted in the first place if it was not nessesary. Quote Link to comment Share on other sites More sharing options...
