PITBULL Posted April 12, 2008 Share Posted April 12, 2008 what oil do u guys recommend i use in my axle with my arb air locker ?? Quote Link to comment Share on other sites More sharing options...
iomlt Posted April 14, 2008 Share Posted April 14, 2008 what oil do u guys recommend i use in my axle with my arb air locker ?? 80 / 90 is fine or you can use 75 / 90. depends if your doing heavy comp's or not! i would say 80 /90 (ep 90) is perfect. what i use Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 14, 2008 Author Share Posted April 14, 2008 80 / 90 is fine or you can use 75 / 90. depends if your doing heavy comp's or not! i would say 80 /90 (ep 90) is perfect. what i use Thanks. I will have to pick some up Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 14, 2008 Share Posted April 14, 2008 what oil do u guys recommend i use in my axle with my arb air locker ?? I think Ive had this conversation somewhere else ARB Specify 90 for normal use , 140 for heavy off road use . Quote Link to comment Share on other sites More sharing options...
PITBULL Posted April 14, 2008 Author Share Posted April 14, 2008 I think Ive had this conversation somewhere else ARB Specify 90 for normal use , 140 for heavy off road use . so am i right in thinkin 140 would be betta as i do off road but its my everyday transport aswell is 140 just betta oil Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 14, 2008 Share Posted April 14, 2008 Well using 140 will cover a lot more uses . 140 is thicker and holds more shock load or Extreme pressure hence "EP" Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 14, 2008 Share Posted April 14, 2008 At work the EP90 equivalent is an oil going by the name of OEP220. (oil Extreme pressure) I may or may not use it in my axles . Good quality oil and fairly cheap . And comes in 25l cans Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 14, 2008 Share Posted April 14, 2008 erm its 85-140w to be more specific, rather then straight 140 oil This may help Nige ARB_SAOM.pdf Quote Link to comment Share on other sites More sharing options...
rick Posted April 15, 2008 Share Posted April 15, 2008 I think Ive had this conversation somewhere else ARB Specify 90 for normal use , 140 for heavy off road use . remember that the recommendation for a xW-140 lube is taking into consideration how hot a Nissan H233B, Ford 9", Dana 60 or other hypoid diff get when used hard (and often in high ambients). They generate much, much more heat (as does a Sals) than a spiral bevel Rover style diff. IMO an xW-140 diff lube is overkill for a Rover diff and an xW-90 sufficient, but generally speaking the heavier the diff oil, the better the crown wheel and bearing protection, so it's up to you. Quote Link to comment Share on other sites More sharing options...
