Bead thickness
white90
  • 2 months later...
I've just pulled all the tyres off the rims and each is 19mm max 20 in places
the inner is HDPE I think
I'm going to call Staworks to see how much 5 new inners shipped will set me back :(
Tony, just rechecked and it came out at 22.88mm and 22.91mm on the one tyre I've got off (compared to pretty much bang on 20mm for the boggers) so I guess there must be variations between batches... I just hope all of mine are the same and that I don't have problems when I come to replace one of them.
I'll see what I can do on the pipe as it will probably be a lot less than Staz sending out stuff from the states. I feel bad that by trying to do you a favour I've caused you yet more hassle with these rims :(
Whats the size of the Inserts Tony , We have skip loads of hdpe pipe kicking about and in some pretty colours ,Blue,yellow and black
450mm external dia
425mm internal dia
these have a small insert that reduces the width to the 425mm the pipe itself is 430mm with a rebate cut in it to fit the reducing insert
