white90 Posted April 13, 2008 Share Posted April 13, 2008 of a Simex ET2 35-10.5-16 please Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted April 13, 2008 Share Posted April 13, 2008 Is someone making beadlocks? Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 13, 2008 Share Posted April 13, 2008 23mm Quote Link to comment Share on other sites More sharing options...
white90 Posted June 24, 2008 Author Share Posted June 24, 2008 No it bluddy isn't!!! 19mm 20 at a push.... Quote Link to comment Share on other sites More sharing options...
will_warne Posted June 24, 2008 Share Posted June 24, 2008 That's what my verniers said and I checked and double checked.... Quote Link to comment Share on other sites More sharing options...
white90 Posted June 24, 2008 Author Share Posted June 24, 2008 wait till you build up the rims I just did one and the insert is flopping about needs new inserts now If I were you I'd measure all you tyres again carefully Quote Link to comment Share on other sites More sharing options...
will_warne Posted June 24, 2008 Share Posted June 24, 2008 Tony, I'll check again. Inserts are 'just' poly pipe - I may be able to get hold of some. Quote Link to comment Share on other sites More sharing options...
white90 Posted June 24, 2008 Author Share Posted June 24, 2008 I've just pulled all the tyres off the rims and each is 19mm max 20 in places the inner is HDPE I think I'm going to call Stazworks to see how much 5 new inners shipped will set me back Quote Link to comment Share on other sites More sharing options...
will_warne Posted June 24, 2008 Share Posted June 24, 2008 I've just pulled all the tyres off the rims and each is 19mm max 20 in placesthe inner is HDPE I think I'm going to call Staworks to see how much 5 new inners shipped will set me back Tony, just rechecked and it came out at 22.88mm and 22.91mm on the one tyre I've got off (compared to pretty much bang on 20mm for the boggers) so I guess there must be variations between batches... I just hope all of mine are the same and that I don't have problems when I come to replace one of them. I'll see what I can do on the pipe as it will probably be a lot less than Staz sending out stuff from the states. I feel bad that by trying to do you a favour I've caused you yet more hassle with these rims Quote Link to comment Share on other sites More sharing options...
white90 Posted June 24, 2008 Author Share Posted June 24, 2008 Will never mind I should have pulled the tyres and checked myself. 5 new inserts are spendy but never mind hopefully shipping won't be so grim as they are light... Quote Link to comment Share on other sites More sharing options...
will_warne Posted June 24, 2008 Share Posted June 24, 2008 What about making up / having made a spacer from 6-8mm plastic sheet - it must be cheaper than new inserts? Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 24, 2008 Share Posted June 24, 2008 Whats the size of the Inserts Tony , We have skip loads of hdpe pipe kicking about and in some pretty colours ,Blue,yellow and black Quote Link to comment Share on other sites More sharing options...
white90 Posted June 24, 2008 Author Share Posted June 24, 2008 Whats the size of the Inserts Tony , We have skip loads of hdpe pipe kicking about and in some pretty colours ,Blue,yellow and black 450mm external dia 425mm internal dia these have a small insert that reduces the width to the 425mm the pipe itself is 430mm with a rebate cut in it to fit the reducing insert Quote Link to comment Share on other sites More sharing options...
