ebdesignDEFENDER Posted April 13, 2008 Share Posted April 13, 2008 I tried to fix my rear door(station wagon hard top) it has broken because the well was hanged on it(as the rear door galss is broken). What can I do to reinforce the door and how to make it to close easyer? Thanks VERY much from EUGEN Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 14, 2008 Share Posted April 14, 2008 personally I'd fit a wheel carrier like Mantec etc. Takes weight off door so you'll have no problems from now on. Then you can repair current door or get a good 2nd hand one or new. Cheers Steve Quote Link to comment Share on other sites More sharing options...
jameslwt Posted April 14, 2008 Share Posted April 14, 2008 Alternatively, if, like me you don't want to spend out more cash just yet, just reinforce it with cross-bracing etc. I have a bit of box section running diagonally across the lower half of the door, and have welded some plates - triangular - across some of the joints in the frame. This seems to have worked quite well - but I don't have an interior trim panel on mine. But ultimately......swing away carrier or remove wheel and stick elsewhere if you have the space. Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted April 14, 2008 Author Share Posted April 14, 2008 has anyone some foto with a repaired door? thanks Quote Link to comment Share on other sites More sharing options...
