BrettS Posted April 15, 2008 Share Posted April 15, 2008 Does anybody have (or can point me in the right direction) pictures of the chassis portion of the 300Tdi motor mounts? We are about to stuff the 300 into my 110 this weekend and I am not sure yet about fabbing up the mounts. Can I just relocate the 2.5 NA mounts or will I need something a little different? Of course if anyone has some measurements on the placement of the new mounts, I would be interested as well. I didn't have much luck doing a search... got back everything but what I was looking for. Must be my technique. Thanks Brett Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 16, 2008 Share Posted April 16, 2008 You'll find the pictures and dimensions here Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 16, 2008 Share Posted April 16, 2008 Or if you want to leave the chassis mounts where they are, make up a new right hand side mount to bolt to the engine, you'll just have to leave some clearance for the oil filter but that's it, nice straight forward fab job on the bench instead of crawling around the engine bay. HTH Mo Quote Link to comment Share on other sites More sharing options...
headdamage Posted April 16, 2008 Share Posted April 16, 2008 Or if you want to leave the chassis mounts where they are, make up a new right hand side mount to bolt to the engine, you'll just have to leave some clearance for the oil filter but that's it, nice straight forward fab job on the bench instead of crawling around the engine bay.HTH Mo You can make a bolt on bracket for the right hand side that fits the stock 2.5na frame mount or you have to weld on a right hand mount? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 16, 2008 Share Posted April 16, 2008 You can make a bolt on bracket for the right hand side to suit the rh mounting. I'm assuming that Brett is bolting up to his old LT77 gearbox. Mo Quote Link to comment Share on other sites More sharing options...
BrettS Posted April 17, 2008 Author Share Posted April 17, 2008 Diesel Jim, thanks for that link. I had seen it before but do you think I could find it again? I should have mentioned that my truck currently has the 2.5 NA mated to an R380, the one with the short bell housing. I have another R380, with the longer bell housing, that came with the 300Tdi that will be going into the truck with the new engine. I am thinking (hoping) that the new gearbox bolts up in the same spot and this in turn pushes the 300 forwards and into the right location. I think it was Western in a previous post that thought this should be correct. The plan would then be to fab up some chassis mounts. One thing I was told is that I should get the engine in the right spot, install the rad and cowl, then centre the fan in the cowl, giving me the correct height. Sound reasonable. Only three more sleeps till the big day! Brett Quote Link to comment Share on other sites More sharing options...
