Thread Size
Pete Attryde
On a Discovery 300TDi EDC engine there is a temperature sensor in the head above number 3 piston anyone know what the thread size is as I want to get an adapter to fit a thermo-ouple to the head instead of the original sensor.
And before anyone says the EDC won't work with out the sensor, I don't have the EDC fitted any more so the sensor is just filling up the hole to prevent coolant loss. ;) .
True, but I am not in a position to remove the sender and check the threads as I can't easily work on the vehicle at work.
I am leaning more towards plan B at the moment, but if I get it wrong I then can't use my truck until I can get a replacement sender / blanking plug or adapter for the thermocouple to stop the coolant from escaping. I suspect it is probably M10x1 but would just like to confirm this before taking the plunge.
Pete.
