chrism Posted May 4, 2008 Share Posted May 4, 2008 Hi guys I have a pair of dana 60`s which i want to lower the gearing from 4.11 to around 4.5 to 5, and i believe series and 101 axles are variants of the dana so any ideas on what would fit and what are the ratios available in 101s and series axles Cheers Chris Quote Link to comment Share on other sites More sharing options...
RobotMan Posted May 4, 2008 Share Posted May 4, 2008 Hi guysI have a pair of dana 60`s which i want to lower the gearing from 4.11 to around 4.5 to 5, and i believe series and 101 axles are variants of the dana so any ideas on what would fit and what are the ratios available in 101s and series axles Cheers Chris The standard Salisbury rear axle from a LWB has a 4.7:1 diff. I can't remember the 101 ratio but I think it is 5.3:1 or there about, quite rare though. Quote Link to comment Share on other sites More sharing options...
jimfoo Posted May 4, 2008 Share Posted May 4, 2008 Why not just buy Dana 60 parts? They come in a ton of ratios. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted May 5, 2008 Share Posted May 5, 2008 The 101 ratio is either 5.56 or 5.58:1,I always confuse the two. You can use the Salisbury 4 pinion carrier in your Dana housings. You can also fit the Dana side gears into them to suit your existing Dana halfshafts. From memory I think I had to mix and match outer pinion bearing cups and cones when I built my front axle from a D60 rear axle with Salisbury ring and pinion and carrier assembly. The Sals pinion shaft was slightly larger in diameter, hence the mix and match. can't remember bearing part numbers but any good bearing supplier should be able to help you there. Bill. Quote Link to comment Share on other sites More sharing options...
