XS Clear Indicators
Are the Clear indicator housings the same as the side light housings?
I have some orange bulbs from my old Mini but the lens where separate and now seem to be bonded to the back.
Thanks
Can't help you with the part number but I can confirm the XS style clear indicator lamp unit is a different lamp unit from the sidelight because of the extra depth of the indicator bulb. The lamps are a one piece assembly with the lens bonded to the lamp body. The bulb holder uses a bayonet fitting into the back of the lamp body.
