wayne1978trucks Posted May 16, 2008 Share Posted May 16, 2008 i have been given, for a few jobs and a beer, a discovery rolling chassis with engine/ box's etc its a 1995 N reg so as the title suggests is it a 300 tdi or 200 and will it be fitted with an lt77 or an r380 box? reason for this is we are in the process of fitting a discovery 200tdi and defender lt77 in a 110 defender could i ( if the 200tdi gives up in the future) fit (if it is) the 300tdi (which i suspect it is) and with my defender td flywheel housing would a defender lt77 box marry up to the 300tdi disco engine? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted May 17, 2008 Share Posted May 17, 2008 i have been given, for a few jobs and a beer, a discovery rolling chassis with engine/ box's etc its a 1995 N reg so as the title suggests is it a 300 tdi or 200 and will it be fitted with an lt77 or an r380 box? reason for this is we are in the process of fitting a discovery 200tdi and defender lt77 in a 110 defender could i ( if the 200tdi gives up in the future) fit (if it is) the 300tdi (which i suspect it is) and with my defender td flywheel housing would a defender lt77 box marry up to the 300tdi disco engine? If its a 95 then its an M plate and will un less its been modified fitted as standard with the 300 and an R380 and the axles will have 24spline diffs.........both can be fitted to either with a bit swaping about but gearbox and engine mounts are different on the chassis and engine/gearbox so would need to be changed......as is your intercooler pipework and a few other bits. Quote Link to comment Share on other sites More sharing options...
sotal Posted May 17, 2008 Share Posted May 17, 2008 N reg came out in 1995 so it probably will be N, M reg came out in 1994. It should be a 300tdi as they were used since 1993 Quote Link to comment Share on other sites More sharing options...
