springs for a disco
old leafer
i have just been given some 110 springs and told they will fit my disco
on the 110 springs the drivers side are longer than the passanger side is this the same on ,my disco befor i rip it to bits to find its wronge
I'm pretty sure the rear springs are a different diameter... in which case they will not fit!!
ty gents i will get me some new rear springs then
If you realy want to fit 110 springs you need to change the top mounts for the 110 ones and the spring seats on the axle.......this is not to hard and also allows you to fit the top chassis mounts where you want them (ie...high for a lift etc).
