SolihullBeast Posted May 25, 2008 Share Posted May 25, 2008 Having decided to convert my 110 to a 100" i have been told I will need to scrap the old 110 fuel tank and fit a 90 fuel tank under the drivers side undercarriage , being a fairly novice mechanic how is this done? are a any common problems with doing this? what type of tank (part number) will I need? is there a bracket available? Sorry if this question is asked a lot on the forum, I haven't found a recent topic about it, any advice would be great, Cheers Sam Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2008 Share Posted May 25, 2008 or start with a unmodded Discovery or RR chassis with the right wheelbase already done, note once built it will need a SVA if intentions to use it as a normal everyday road vehicle Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 25, 2008 Share Posted May 25, 2008 You'll need the little Y shaped bracket that bolts to the bulkhead outrigger, part n. NRC9474, and a new tubular outrigger to support the back of the tank. you can either buy the outrigger as a weld on part STC8648 or just use a piece of round tube. Quote Link to comment Share on other sites More sharing options...
