v8bobber Posted May 25, 2008 Share Posted May 25, 2008 Hello all, I've recently bought a LR90, without an engine. It was formerly a 2.5 diesel so i've bought a replacement engine of the same type which is now in and bolted down nicey thank-you-very much. Fuel and electrics are all plumbed back in but I have happened on a snag. I cannot see how the throttle cable links to the throttle linkage on top of the injector pump. The throttle cable has no "end" on it as such and the linkage just has a hole on it. Has anyone got a 2.5 diesel who can advise as to how the two go together, or does anyone else know? Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 26, 2008 Share Posted May 26, 2008 There should be a linkage assembly that attaches to the vacuum pump. The cable goes into that and there is a rod that connects to the pump. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 26, 2008 Share Posted May 26, 2008 Here is a picture of the parts page. #11 bolts to the vacuum pump and #12 connects to the pump. The cable should have a clevis end, but I suppose you could rig something up. Quote Link to comment Share on other sites More sharing options...
