draper40 Posted May 26, 2008 Share Posted May 26, 2008 Hey, I have an alternator off a 200tdi disco and a 200tdi defender engine. They look the same but are they different rating's? How do I tell? Thanks Pete Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2008 Share Posted May 26, 2008 should be a label stating the make/model/amperage on it, IIRC Defender 200Tdi standard alt. is or was a 45amp & Discovery 200TDi had a 65amp. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 26, 2008 Author Share Posted May 26, 2008 There is a label on it that has a barcode and then what looks like a date a possibly a serial number but not the amperage. Pete Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2008 Share Posted May 26, 2008 can you put up a picture of the label, might be able to decode it. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 26, 2008 Author Share Posted May 26, 2008 Western, Thnumbers/letters are as follows: Top left (below bar code): R5907 Top right: DD Bottom left: 24403 Bottom Right (below DD): 3/16/03 Any idea? Pete Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2008 Share Posted May 26, 2008 The 24403 is a Lucas part number. in the 110 1987 on parts book a 65amp is Lucas 24220 45amp is Lucas 24199 still hunting for the amp rating of a 24403 alt. Bottom Right (below DD): 3/16/03 = a build date 16th March 2003 Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 26, 2008 Author Share Posted May 26, 2008 The other is a 2005 with the part number starting with a 6. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 26, 2008 Author Share Posted May 26, 2008 The 2003 is a disco one if it helps. Pete Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2008 Share Posted May 26, 2008 found a 72amp & a 85 amp alternator in the EPC Discovery V8 EFI section, doesn't give any Lucas part numbers for comparison though, can't find the 24403 on the Lucas Europe website, it just says 'no search results'. probably the quickest way to find the amp rating is get a auto electrics place to put it on their test rig. Quote Link to comment Share on other sites More sharing options...
