chris1965.2A Posted May 26, 2008 Share Posted May 26, 2008 Hi One of the core plugs on the side of my 3 bearing 2 1/4 1965 2A landys engine block is leaking. Its the dip stick side and there are 3 core plugs im not sure if they are metric or imperial. If any one has any info or size i would be greatful Many thanks Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 27, 2008 Share Posted May 27, 2008 Part number for the core plugs is 525428 or ERC4996. These are just listed as 'alternatives' with no explanation. Les. Quote Link to comment Share on other sites More sharing options...
chris1965.2A Posted May 27, 2008 Author Share Posted May 27, 2008 Part number for the core plugs is 525428 or ERC4996. These are just listed as 'alternatives' with no explanation.Les. Thanks less i have done a search and the 525428 is 1 7/8 and the ERC4996 is 52mm Dia so im ging to order 3 off each just in case Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 27, 2008 Share Posted May 27, 2008 525428 = 3 bearing units ERC4996 = 5 bearing units. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 27, 2008 Share Posted May 27, 2008 There's a man that knows Thanks Phil. Les. Quote Link to comment Share on other sites More sharing options...
chris1965.2A Posted May 27, 2008 Author Share Posted May 27, 2008 Thanks Phil. I will order a set tomorrow Quote Link to comment Share on other sites More sharing options...
