dantd5 Posted June 8, 2008 Share Posted June 8, 2008 The days of rest are over.. The problem currently is on my td5110 99 model. Whenever I come up to 4th gear, there is cranking noise. Even though not bothersome nor high pitched, it turns to worry me a little. A stitch in time saves nine... like the good saying goes... I am actually suspecting the back axel needs some refill of oil or maybe oil the crank shaft... But i did the oil change only last November... Anyway despite my guesses I felt it wise to notify the big DONS of the forum for noble advices... Description of the noise... Grrrr GRrr blang blang kakakakaka... There is more of a kakakakaka than blang blang.... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 8, 2008 Share Posted June 8, 2008 Sounds like a bearing breaking up somewhere - I would not drive it until you find out what! Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 8, 2008 Author Share Posted June 8, 2008 getting the creeps down my spine...... Better not... I will check it out then....Thanks .. Quote Link to comment Share on other sites More sharing options...
