TheBeastie Posted June 8, 2008 Share Posted June 8, 2008 The Beastie is a 1991 200Tdi and it has developed a weepy clutch master cylinder. I am trying to source a replacement. The EPC software suggests 550732 when I put in my VIN. Craddocks do not recognise but Paddocks do. They have two - one unbranded at £10.43 (550732R) and a Lucas one at £19.40 (550732G). I assume that means replacement and genuine. Would I be right in thinking that I am better getting a genuine Lucas one since hopefully the new one will last for a long long time or am I making an incorrect judgement there? Also are there any other bits I am likely to need to complete the job - like do some parts typically corrode and also get replaced at the same time? I ask since I need to try and do the job in one session and get The Beastie back on the road, not lose a week whilst I wait for some unexpected part to arrive. I already have a big bottle of brake fluid and know I will need to try and get some clear piping to bleed the system. Thanks and best wishes Malcy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 8, 2008 Share Posted June 8, 2008 Use the Lucas master cylinder - they are far better than unbranded ones. Apart from fresh fluid and a means to bleed the system, I don't think you need anything else unless it all goes pear-shaped Les. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted June 8, 2008 Author Share Posted June 8, 2008 Thanks I will order up and keep fingers crossed. Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2008 Share Posted June 8, 2008 the G on the end of the Paddocks part number = genuine [their reference] 550723 is the older superseded number try STC100410, transfer the pipeline adaptor & reset the pedal pushrod as per the workshop manual [copy below] Quote Link to comment Share on other sites More sharing options...
