bishbosh Posted June 17, 2008 Share Posted June 17, 2008 I seem to have thrown away some bits that I actually need They are - TD engine mount rubbers, I believe the P/N is ANR1808? Also, the complete LT230 gearbox mount - the bracket that mounts to the gearbox and the rubber (ANR1808 again?) and the bracket that mounts to the chassis. For a 1989 90 if that makes any difference.... So who's going to beat Ralph to it......? Thanks, Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 17, 2008 Share Posted June 17, 2008 You're right with the part numbers for the rubbers, same for engine and transfer box: the other parts: the little square plates (#9 on the transferbox picture) was NRC8204, now superceded to WC110067L LH chassis bracket is NRC5743 RH bracket NRC5742 main chassis bolts M8x100 bigger bolts (square plates to transferbox) M12x20 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 17, 2008 Author Share Posted June 17, 2008 Thanks Jamie! Ralph, you're slipping!! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 17, 2008 Share Posted June 17, 2008 Ralph, you're slipping!! he's probably doing what i should be doing...... work! ,yuk, horrible word! Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2008 Share Posted June 17, 2008 he's probably doing what i should be doing......work! ,yuk, horrible word! Yep, sorting loads of paperwork for a aircraft Primary [150 hour] maintenance check & a engine change Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 17, 2008 Author Share Posted June 17, 2008 OK then Ralph, heres your chance to even the score.... Need a P/N for a ZF auto (RRC stylee) output shaft oil seal please..... The one I have is more oil than seal now... Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2008 Share Posted June 17, 2008 RTC4650 Common seal to all ZF auto boxes in all models inc Defender Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 17, 2008 Author Share Posted June 17, 2008 Cheers Ralph! Jamie - looks like the Master has put you in your place!! Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2008 Share Posted June 17, 2008 Cheers Ralph!Jamie - looks like the Master has put you in your place!! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 18, 2008 Share Posted June 18, 2008 Cheers Ralph!Jamie - looks like the Master has put you in your place!! Ahh... but Jamie was in a better place..... in bed next to the blonde haired master... Quote Link to comment Share on other sites More sharing options...
western Posted June 18, 2008 Share Posted June 18, 2008 Oi, thats not for this site Quote Link to comment Share on other sites More sharing options...
