Graham Thomson Posted June 22, 2008 Share Posted June 22, 2008 For the past week or so, I've had no "dipped" light in the nearside lamp. Main beam is fine, sidelight works fine. Changed the bulb this evening to see if that was the problem - unfortunately it wasnt. Any ideas where I go next? Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2008 Share Posted June 22, 2008 tried the fuses ? left & right dip & main beam have their own 8amp fuse. Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted June 23, 2008 Author Share Posted June 23, 2008 Oh. Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2008 Share Posted June 23, 2008 Oh. :rofl:I guess you didn't check the fuses then, after I sent you the label for the fuse box too so have ya fixed it ???? Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted June 23, 2008 Share Posted June 23, 2008 If not the fuses, the wires that run from the lights along the wings, may have wear in the insulation which touches the body work. Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted June 24, 2008 Author Share Posted June 24, 2008 :rofl:I guess you didn't check the fuses then, after I sent you the label for the fuse box too so have ya fixed it ???? I know I know - and actually I havent looked at the fuse yet - just been too damn busy!! Will try to get to it tonight. Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted June 25, 2008 Author Share Posted June 25, 2008 Finally had a look at the fuses.......over the years all seem to have been replaced with slightly higher rated ones! (although I suspect that the various owners just put in what they had to hand!!). Anyway, the 10amp fuse I removed looked absolutely fine, so no joy there. Must be a wiring problem! Hmmph! Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted June 25, 2008 Share Posted June 25, 2008 Graham, if you stick your hand under each wing & find the loom from each headlight & then trace along that group of wires back towards the bulkhead, you may find that where the wires move against the body, the insulation has worn away. I had this problem & discovered where the weak point was in just a couple of minutes. Just wrap a bit of new insulation around that point, or even better along the entire length. Martin Quote Link to comment Share on other sites More sharing options...
western Posted June 25, 2008 Share Posted June 25, 2008 Graham, pull the fuses & clean the contacts the fuses sit in, sometime even a slightest bit of dirt/corrosion will afect the current to the lights Quote Link to comment Share on other sites More sharing options...
