scooby Posted June 27, 2008 Share Posted June 27, 2008 ello members having read about oil getting in the injector loom on the td5 i have been wondering if mine has got the bug i seem to get an uneven tickover now and again , i notice it more through the gear stick and sometimes a lack of power when pulling away from a standing start , so where can i check it for oil in the loom and it's location please p.s while i'm on a roll i here my air spring valve exhaust every so often is this the norm ? the springs are in good nick and it stays up and level at all times running or not , when i had my first td5 many years ago i never recalled hearing it then again i only kept it for 4 months Quote Link to comment Share on other sites More sharing options...
JST Posted June 27, 2008 Share Posted June 27, 2008 ecu is under the bonnet, have a look at the plugs going into it and see if there is evidence of oil there. i'm a defender man but think the ECU is in front of the battery box or the ABS pump. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 27, 2008 Share Posted June 27, 2008 correct - next to battery Quote Link to comment Share on other sites More sharing options...
scooby Posted June 27, 2008 Author Share Posted June 27, 2008 correct - next to battery cheers chaps i'll get on it tomorrow as i said loads of power just a bit sluggish when pulling away , a bit like turbo lag but with the intermitent vibration from stick it makes me think it maybe dropping off on a pot Quote Link to comment Share on other sites More sharing options...
