renault4 Posted June 27, 2008 Share Posted June 27, 2008 I am about to replace my clutch and have read that I should use molybdenum disulphide grease on the lever pivot, the slipper pads and the release bearing carrier. Is this a special grease (and therefore neccesary) or will normal lithium grease do? Quote Link to comment Share on other sites More sharing options...
western Posted June 27, 2008 Share Posted June 27, 2008 Defender workshop manual says molybdenum disulphide grease on the release bearing slide tube, only a very thin smear though otherwise it could get onto the friction plate surface. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 27, 2008 Share Posted June 27, 2008 I think there's a bit of a misunderstanding here about grease. What LR says, "molybdenum disulphide grease", means a grease that contains molybdenum disulphide (MD). This MD is a solid lubricant, more on http://en.wikipedia.org/wiki/Molybdenum_disulfide Generally speaking, a grease, same as oils, has a base and then it has additives. One of the additives can be (in this case must be) MD. So, what LR says is this: use any grease which has MD as an additive. Lithium grease means a grease with a lithium base, which can have numerous additives, including MD, more on http://en.wikipedia.org/wiki/Lithium-based_grease renault4, if your Lithium grease contains MD then it's good to go. Check what is says on the tin or search the manufacturer's site for its tech sheet. Quote Link to comment Share on other sites More sharing options...
