tomaco1 Posted June 28, 2008 Share Posted June 28, 2008 I'm looking at an elec circuit Diagram for the A/C in a 1985 90 and I can't for the life of me find the condenser fan relay, compressor clutch relay, and the resistor block. Any Help would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted June 28, 2008 Share Posted June 28, 2008 blower fan relay behind the metal fuse panel below the dash & in front of gear shift levers, take off the black fusebox cover, peel back the matting up each side & remove the 2 screws [1 each side] ease the fusebox towards the gearshift & relays are cippled to the back. 2 more located on inner edge of right hand side front wing [fender] Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted June 29, 2008 Author Share Posted June 29, 2008 blower fan relay behind the metal fuse panel below the dash & in front of gear shift levers, take off the black fusebox cover, peel back the matting up each side & remove the 2 screws [1 each side] ease the fusebox towards the gearshift & relays are cippled to the back. 2 more located on inner edge of right hand side front wing [fender] Thanks, I assume it would be reversed on a LHD truck, I"ll look in the AM. Quote Link to comment Share on other sites More sharing options...
western Posted June 29, 2008 Share Posted June 29, 2008 not sure, but would except the to be in the same place regadless of left or right hand drive. got the locations from my 110 1987 on parts book. Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted June 29, 2008 Author Share Posted June 29, 2008 not sure, but would except the to be in the same place regadless of left or right hand drive. got the locations from my 110 1987 on parts book.Thanks AgainI found them today. Quote Link to comment Share on other sites More sharing options...
western Posted June 29, 2008 Share Posted June 29, 2008 Quote Link to comment Share on other sites More sharing options...
