PEASEY Posted July 1, 2008 Share Posted July 1, 2008 Hi chaps,could someone shed some light on my problem please?Im getting oil which i think is engine oil dripping out of the gear box wading plug hole,i havent got the plug fitted in as i wanted to see how much i was looseing.can anyone tell me if its the rear crank shaft oil seal thats leaking or if its something else? could i just slide the gear box back to replace it or is it gear box out time? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 1, 2008 Share Posted July 1, 2008 yes it's time for a new crank oil seal no sorry you can't slide the gear box back gearbox out, but you may find it easyer to take the engine out to do it as the seal as it sits in the bell housing and the gearbox can be an arse to take out if you don't have the right kit Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 1, 2008 Share Posted July 1, 2008 I did it by sliding the gearbox back Les Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 1, 2008 Share Posted July 1, 2008 I did it by sliding the gearbox back Les i'll take it back then never did it but if you've done it must be possable. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 1, 2008 Share Posted July 1, 2008 If you look at this thread, which is a Disco clutch change I did, the gearbox is moved backwards far enough to replace the clutch. Not much room, but once the flywheel is off you will have about 3-inches more. http://forums.lr4x4.com/index.php?showtopic=6719 Les. Quote Link to comment Share on other sites More sharing options...
PEASEY Posted July 1, 2008 Author Share Posted July 1, 2008 Thanks chaps for your replies,is the proceedure still roughly the same as in les clutch change as i have an auto gear box,sorry i should have popped that in my original post. Quote Link to comment Share on other sites More sharing options...
