Gingerlandy Posted July 1, 2008 Share Posted July 1, 2008 Does one know if a 1983 ranger rover rear diff will fit a k plate 3.5i Disco mine has given up half the teath are now missing on the planet gear Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 1, 2008 Share Posted July 1, 2008 The RR diff will be a 10 spline halfshaft, not sure about the Discovery at that age, at some point around then it changed from 10 to 24 spline. If it is a 10 spline diff it should go straight in if you are changing the whole thing, if it is a 24 spline then you would need new halfshafts etc. Quote Link to comment Share on other sites More sharing options...
Mark Posted July 1, 2008 Share Posted July 1, 2008 As Mr Monster has said - depends on the year of your Discovery... The k-plate disco I had was a 10spline rear axle, so yes, that should fit fine - best to count the splines on the end of the halfshaft to be sure tho. Mark Quote Link to comment Share on other sites More sharing options...
Gingerlandy Posted July 1, 2008 Author Share Posted July 1, 2008 As Mr Monster has said - depends on the year of your Discovery... The k-plate disco I had was a 10spline rear axle, so yes, that should fit fine - best to count the splines on the end of the halfshaft to be sure tho. Mark Thanks will keep me going till the next one breaks !!!! Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted July 1, 2008 Share Posted July 1, 2008 Yes should be OK .................... 24 spline diffs came into the disco's in 94 ............. M plate Ian Quote Link to comment Share on other sites More sharing options...
