td5 edu / safe or not
scooby
ok folks this may seem lazy but it's about speed
is it safe to remove and refit the 2 connection plugs from the ecu on my td5 to check for oil in the loom while the battery is still connected ?
the fact that i do not have the radio code is the reason and it would mean having to go to the main steelers with the log book
and may even have to pay :angry: ,
i tried to fit the job in this weekend but hav'nt had time , if i know there's oil in the loom it's still in warranty as i've only had it
a month so the garage can deal with it if it has , plus i will know for a fact there's oil in the loom that way they wont be able to fob me off
and they can get the code for the radio ;)
TOPIC SHOULD READ ECU , SORRY
Turn the ignition off and wait for a relay "click" after about 15 sec then no problems at all.
thanks lads ;)
did'nt need to unplug ecu there was oil clearly at the bottom of the black plastic box which ecu and jack are in
so it's back to the garage next week , not a good start :(
