scooby Posted July 1, 2008 Share Posted July 1, 2008 ok folks this may seem lazy but it's about speed is it safe to remove and refit the 2 connection plugs from the ecu on my td5 to check for oil in the loom while the battery is still connected ? the fact that i do not have the radio code is the reason and it would mean having to go to the main steelers with the log book and may even have to pay , i tried to fit the job in this weekend but hav'nt had time , if i know there's oil in the loom it's still in warranty as i've only had it a month so the garage can deal with it if it has , plus i will know for a fact there's oil in the loom that way they wont be able to fob me off and they can get the code for the radio TOPIC SHOULD READ ECU , SORRY Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted July 1, 2008 Share Posted July 1, 2008 No problem,just turn the ignition off and unplug them. Quote Link to comment Share on other sites More sharing options...
scooby Posted July 1, 2008 Author Share Posted July 1, 2008 cheers allyV8 just worried incase i caused some type of spike in the ecu and sent it loopy Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 2, 2008 Share Posted July 2, 2008 Turn the ignition off and wait for a relay "click" after about 15 sec then no problems at all. Quote Link to comment Share on other sites More sharing options...
scooby Posted July 4, 2008 Author Share Posted July 4, 2008 Turn the ignition off and wait for a relay "click" after about 15 sec then no problems at all. thanks lads did'nt need to unplug ecu there was oil clearly at the bottom of the black plastic box which ecu and jack are in so it's back to the garage next week , not a good start Quote Link to comment Share on other sites More sharing options...
