LDRover Posted July 29, 2008 Share Posted July 29, 2008 I am looking to install second battery on 200TDI Discovery in the passenger side battery tray. Could anyone tell me the best way to route the cables between them before I start taking it apart. Thanks. Quote Link to comment Share on other sites More sharing options...
LDRover Posted July 30, 2008 Author Share Posted July 30, 2008 There is a gap between the rad and front slam panel which I could just get the cables in. Would it be OK to run the 2 cables so close to the rad. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 30, 2008 Share Posted July 30, 2008 As long as they are properly secured and protected from chafing it shouldn't be a problem Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted July 31, 2008 Share Posted July 31, 2008 Thats the way I've run my cable. You dont need two, just +ve to +ve and run a shorter earth to the chassis under the second battery. The cable is more expensive than a second hand battery so you'll save £££'s Quote Link to comment Share on other sites More sharing options...
