AJL Posted January 12, 2006 Author Share Posted January 12, 2006 Kev is right BUT if you are having to do that on a hill you have an EMS fault. You should be able to pull away on a 1in6 with no throttle thanks to the anti-stall. In low you should be able to pull away in first on a 45 degree slope with a full load with no throttle.I will have a look in the unofficial TD5 faults book tomorrow. BTW Kev if you read this can you ring me David if you could have a quick look in your book it would be most appreciated! Thanks James Quote Link to comment Share on other sites More sharing options...
John_T Posted January 12, 2006 Share Posted January 12, 2006 John_T I have blanked off several EGR systems and to the best of my knowledge the only fault normally stored is with the EGR system on the ones I have done, no running problems. Td5s create airflow faults, injector faults, wiring faults, sensor fault, kitchen sink faults, and anything else you can think of but it doesn't mean there is anything wrong. I was looking at one today which had 13 different fault codes stored and there was actually nothing wrong with it.... I think they suffer a little from hypochondria Aha....that explains the sneezing noise it made this morning.....I'll go and pop a paracetamol in the tank to keep it happy! Quote Link to comment Share on other sites More sharing options...
Petergg Posted January 12, 2006 Share Posted January 12, 2006 I have had my EGR off for some while. I had a new ECU programmed in for a spare, the only Fault codes on my old one were ABS fault 18 times LH side rear . My Exhaust has 1 box at the front on down pipe. Peter Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted January 12, 2006 Share Posted January 12, 2006 BTW Kev if you read this can you ring me David PM sent. kev Quote Link to comment Share on other sites More sharing options...
AJL Posted January 17, 2006 Author Share Posted January 17, 2006 Well as an update to this thread my problems were centred around not the ECU (of which i now have a spanking new spare) but with a non operational air flow meter this was picked up by Autologic test book this afternoon. Purchased a new airflow meter and hey presto throttle response back to normal plus the engine has got more go! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 17, 2006 Share Posted January 17, 2006 Well as an update to this thread my problems were centred around not the ECU (of which i now have a spanking new spare) but with a non operational air flow meter this was picked up by Autologic test book this afternoon. Purchased a new airflow meter and hey presto throttle response back to normal plus the engine has got more go! Ah so when I said However a genuine airflow meter fault can produce a massive power loss, I have seen two with this fault in the last six months or so, dodgy readings from the airflow meter produced a big loss of power but no fault code, it was only picked up with a voltmeter and swapping in another AFM. I wasn't too far wrong then Quote Link to comment Share on other sites More sharing options...
AJL Posted January 17, 2006 Author Share Posted January 17, 2006 Many thanks to everyone who contributed to this thread! PSST (anyone want to buy a new ECU?) Quote Link to comment Share on other sites More sharing options...
