drkwack Posted August 10, 2008 Share Posted August 10, 2008 Hi, in the process of finally getting my disco back together, its a 95 300, my question is:- would i get better gear ratio's by fitting a transfer box from my old 200 def 90. Having fitted 235.85x 16 insa turbo dakars and 2" suspension, or wont it alter road gearing or not fit or no benifit ?????? Quote Link to comment Share on other sites More sharing options...
gelf Posted August 10, 2008 Share Posted August 10, 2008 hi ya.......... with that size tyre, i dont think it would be worth the work......... if it had 35" fitted then i think the transfer box would make the gearing normal again, so with the 235s it would be under geared. someone correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 10, 2008 Share Posted August 10, 2008 The difference in size between the std Disco tyres and the 85s is only 6.2% The 1.44 90 transfer box will gear it down more than that. Yes, you will be undergeared with 235/85s. Quote Link to comment Share on other sites More sharing options...
drkwack Posted August 12, 2008 Author Share Posted August 12, 2008 The difference in size between the std Disco tyres and the 85s is only 6.2% The 1.44 90 transfer box will gear it down more than that. Yes, you will be undergeared with 235/85s. THANKS for replys. take it I dont fit the 90's transfer box. Quote Link to comment Share on other sites More sharing options...
