JonR Posted August 21, 2008 Share Posted August 21, 2008 Any ideas as to what would currently be the nearest equivalent to the aforementioned shock absorber? Are they still around in a different guise? Thanks in advance. Jon. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 21, 2008 Share Posted August 21, 2008 They are no longer available and I think the replacement in the Monroe range is called the Adventurer, I had a set of GM's and then a set of Adventurers on a later vehicle, didn't seem to be much difference between them to me. Quote Link to comment Share on other sites More sharing options...
JonR Posted August 21, 2008 Author Share Posted August 21, 2008 I think the Adventurer is of cheaper build quality compared to the Gas Magnum, they certainly lack the cushioning (bump stop?) at the end of the compression stroke. The price differential would also suggest a difference in quality; Adventurers are around £29 whilst Gas Mags were around £42. Monroe do a range of shocks for commercial vehicles called Truck Magnum, I think, but that is as far as my knowledge of them goes. I seem to recall reading something, where it was suggested that the Gas Magnum became the OME shock, or it just might have been that OME was recommended as a viable alternative. However, with OME nearly £90 each now, viable just doesn't come into it. Jon. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 21, 2008 Share Posted August 21, 2008 All I know is that I asked Famous Four for Gas Magnums when I wanted some new ones, and was told that the Adventurer replaced them, maybe a bit of cost cutting in the process then! The OME stuff is too expensive, and in the few OME equipped vehicles I have been in here it shakes all your teeth out on rough roads Quote Link to comment Share on other sites More sharing options...
