66gaza Posted September 23, 2008 Share Posted September 23, 2008 Hi, are all the crossdrilled input gears also longer splines for more contact? could someone who has an LT230 handy with the crossdrilled I/P gear measure from the gearbox mating face to the start of the splines, I would be very grateful. Gaza Quote Link to comment Share on other sites More sharing options...
66gaza Posted September 23, 2008 Author Share Posted September 23, 2008 Can anyone measure the output shaft of a LT77 of a R380 and I can work from there. thanks Gaza Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 24, 2008 Share Posted September 24, 2008 Bear in mind there are 3 or 4 different ones available depending on what the serial numbers etc of the boxes are. Jon Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 24, 2008 Share Posted September 24, 2008 I just happen to have one in the garage It's difficult to measure the internal length of the splines but by pushing a roll of paper in there and marking it with finger pressure, the splines look to be 72mm long. Quote Link to comment Share on other sites More sharing options...
Lars L Posted September 24, 2008 Share Posted September 24, 2008 Measure or not, I have LT77 together with a LT230 from a 2001 Td5 Defender. Which I assume has the cross drilled gear. No problems. Quote Link to comment Share on other sites More sharing options...
66gaza Posted September 24, 2008 Author Share Posted September 24, 2008 I just happen to have one in the garage It's difficult to measure the internal length of the splines but by pushing a roll of paper in there and marking it with finger pressure, the splines look to be 72mm long. Thanks for that, can you possibly tell me how far in from the mating face do the splines start? Thanks Gaza Quote Link to comment Share on other sites More sharing options...
