discobandit Posted September 28, 2008 Share Posted September 28, 2008 Hi all, fitted a kenlowe fan a while back being powered directly from the battery. This isn't causing major problems but when the sun does finally come out it does sometimes continue to run after the engine is switched off. The question is where can I take a feed from so that it will only run with the ignition on? Cheers Gary Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 28, 2008 Share Posted September 28, 2008 The simplist way would be to fit a relay so that the main feed still comes from the battery but the relay is switched by an ignition controlled supply. Pete. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2008 Share Posted September 28, 2008 The simplist way would be to fit a relay so that the main feed still comes from the battery but the relay is switched by an ignition controlled supply. ^^ This ^^ You won't find a spare 30A ignition-switched live feed in a Landy, use a FUSED feed from the battery to the relay and then an ignition switched live to switch the relay on. Quote Link to comment Share on other sites More sharing options...
