clemo2k1 Posted October 12, 2008 Share Posted October 12, 2008 when i changed front pads the pistons in the passenger side were a joke to get back in whereas the drivers side i just pushed in by hand will stripping the caliper clening it out and putting new seals in fix the problem or should i put four new pistons in?? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 12, 2008 Share Posted October 12, 2008 Depends on the condition of the pistons but if I was going to the trouble of stripping the caliper I would not bother changing the seals and not the pistons. Quote Link to comment Share on other sites More sharing options...
sparkyk80 Posted October 12, 2008 Share Posted October 12, 2008 i would replace the caliper can get a new one for 60 pounds Quote Link to comment Share on other sites More sharing options...
teabag Posted October 12, 2008 Share Posted October 12, 2008 Corrosion on the piston that is lifting the chrome plating so they are sticking the permanent fix is to replace the piston or fit a peplacement caliper s/h or new. Quote Link to comment Share on other sites More sharing options...
