Mean Green Posted October 12, 2008 Share Posted October 12, 2008 My 1993 Defender has developed a very bad judder in reverse which is coupled to a loud banging and clunking. It only happens in reverse, initially it was only under load - ie reversing up the smallest of inclines, however it is now everytime you reverse. The only way to make any progress in reverse is to constantly dip the clutch. Suggestions and help please!! Quote Link to comment Share on other sites More sharing options...
Kev C Posted October 13, 2008 Share Posted October 13, 2008 No help but I'm experiencing this as well. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 13, 2008 Share Posted October 13, 2008 Check your handbrake or rear brakes aren't binding. Also gearbox mounting rubbers. If brakes are adjusted to close to the drum, they sometimes turn in the normal direction of rotation (driving forwards), but bite into the drum when going the opposite way. Does it only do it whern reversing after the handbrake is released? Could be adjustment of the handbrake - either too slack or too tight. Les. Quote Link to comment Share on other sites More sharing options...
TJN Posted October 14, 2008 Share Posted October 14, 2008 This is what mine did before I found the transfer box was knackered. Mine was the main shaft bush had chewed itself apart and the main shaft that the two props attach to was moving. I would drain you Tbox oil and have a look for lots of metal on the sump plug and then remove the inspection plate and see if you can see any wear on the cogs. Or bits of cogs. The next thing I did was raise the vehicle off the ground and lie underneath as someone "drove" it in reverse and I could see the shaft moving. And hear the Clunk Bang! I do hope this isnt what your is doing but I fear it maybe. TJ Quote Link to comment Share on other sites More sharing options...
Defwestender Posted October 14, 2008 Share Posted October 14, 2008 "Or bits of cogs. The next thing I did was raise the vehicle off the ground and lie underneath as someone "drove" it in reverse and I could see the shaft moving. And hear the Clunk Bang!" I wouldn't fancy lying down on the ground when any of my mates were driving I'm getting a clunk on mine too, is it a big job changing a transfer box, it seems relatively easy to get to. Quote Link to comment Share on other sites More sharing options...
yellow Posted October 14, 2008 Share Posted October 14, 2008 Changing a Tbox is quite straight forward. Make sure that the handbrake bracket fits well before refitting, as they differ slightly between versions. Should be a 4 hour job if it is the first time, including tea and biscuits... Oh, almost forgot, be aware of the 'hidden' bolt... Quote Link to comment Share on other sites More sharing options...
TJN Posted October 14, 2008 Share Posted October 14, 2008 Yeah not a long job, an hour to get the old one off anf then 3 to get the new one on as the speedo drive was stuck in the box and this caused "issues" Worth getting the cover plate off to have a look around if you are getting strange noises. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted October 14, 2008 Author Share Posted October 14, 2008 Thanks for the suggestions - I was suspecting gearbox, but I didnt think of transfer box! I think a cllose look is required Quote Link to comment Share on other sites More sharing options...
Kev C Posted October 18, 2008 Share Posted October 18, 2008 No help but I'm experiencing this as well. Turned out to be the handbrake binding in reverse on mine. Not unhappy as that has to be the cheapest option Quote Link to comment Share on other sites More sharing options...
