stuntman Posted October 15, 2008 Share Posted October 15, 2008 Hello one and all. I know I've been asking a lot of questions the last week or two but I really need help with this one. I have a 300 tdi engine mounted where my V8 used to be. I have managed to sort the ignition wiring and I now have a constant 12v supply wire (when key in normal running postion) and one that is a 12v supply when the ignition is used (spring loaded key position for starting) My questions are, where do I connect these! I'm sorry for all these seemingly stupid questions but I'm so closed to finishing my dream landy, I just want to hear it run!. Thanks in advance Andi PS I'm alwyas greatfull for any help. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 15, 2008 Share Posted October 15, 2008 You need to make sure that whichever supply you use - it remains live while the starter motor is spinning. I made this mistake when I fitted a 2.5D in my 109. Les. Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 15, 2008 Author Share Posted October 15, 2008 Les, I have 12v when the key is on the ignition live postition, normal running postion. And I have 12v when I turn the key to start. I just need to know where i connect these to Quote Link to comment Share on other sites More sharing options...
Lars L Posted October 15, 2008 Share Posted October 15, 2008 Have you connected the solenoid valve on the pump to a wire that is fed even when the starter is engaged? That's a must to get it started. One or both of the two wires that you have "over" might be the ones to use... Frankly, I don't know much about V8 wiring, but they can be for the ignition coil. One wire feeding full 12 v when starting and the other through a resistance after it has started. And of course, I can be completely wrong... Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 15, 2008 Share Posted October 15, 2008 "12v when the key is on the ignition live postition, normal running position" Does this wire remain live when the ignition key is turned to the spring loaded 'start' position? If so, connect this to the stop solenoid in the injection pump. If this wire does not remain live, look at the wire that is ONLY live when the key is in the start position. Is there another wire like this on the back of the ignition switch, possibly White Red, and going to the starter motor solenoid small spade terminal? Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 15, 2008 Author Share Posted October 15, 2008 Hello David. I have 12v live in the normal position constantly, even when the key is then turned the starting/ cranking position, this position gives a 12v feed to another wire that is only live when the key is in this position. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 15, 2008 Share Posted October 15, 2008 OK, The wire that is live in both positions, run and starting, will go to the solenoid, so that it will be operated in both the Start and Run positions. The wire that is only live in the starting position will go to the Starter solenoid, as I said earlier. Cheers. Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 15, 2008 Author Share Posted October 15, 2008 You sir are a gentleman. I'll be playing tonight Quote Link to comment Share on other sites More sharing options...
