Off Road Toad Posted October 28, 2008 Share Posted October 28, 2008 Don't know if anyone has an answer for this, My windscreen wipers in my 98 300tdi 90" seem to be stuck on. i can switch them to fast mode or normal speed but i can't turn them off or to intermittent. I have done the following: Replaced the park sensor: no difference Replaced the main switch: no difference Replaced the relay: started working again for 3 days and now back to it's original problem again. Do you think i've been unlucky with a duff new relay or perhaps an underlying problem causing relays to fail? Maybe even something else i haven't tried yet? any thoughts on this would be much appreciated. i know it's only a small trhing but it's properly annoying! Cheers, Steve Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted October 28, 2008 Share Posted October 28, 2008 It may be worth checking that it's all earthed properly as I have just had a similar problem on a 110 and it was down to a broken earth. Pete. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted October 28, 2008 Author Share Posted October 28, 2008 It may be worth checking that it's all earthed properly as I have just had a similar problem on a 110 and it was down to a broken earth.Pete. Thanks i'll look at that. Steve Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2008 Share Posted October 28, 2008 should be a earth lead from the motor body to a tag at the bulkhead [1 of the motor strap screws secures the tag to the bulkhead] Quote Link to comment Share on other sites More sharing options...
