k9unit Posted November 4, 2008 Share Posted November 4, 2008 morning all who sells a de cat pipe for the disco 1 300tdi with the flexy bit in it cheers paul Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 4, 2008 Share Posted November 4, 2008 Most Landrover spares places should be able to get you one as it's a standard part. P/N ESR2740. paddocks list for £59 + vat. Pete. Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 4, 2008 Share Posted November 4, 2008 I replaced mine with a downpipe from a 300Tdi 110... it has no flexi in it but has made no difference to the noise or vibration, but made a noticeable difference to the performance, and was only about £20... Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 4, 2008 Share Posted November 4, 2008 I replaced mine with a downpipe from a 300Tdi 110... it has no flexi in it but has made no difference to the noise or vibration, but made a noticeable difference to the performance, and was only about £20... So did I but, I was just supplying the info asked for . Pete. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 5, 2008 Share Posted November 5, 2008 So did I but, I was just supplying the info asked for .Pete. Have you got the part # ?? as i am interested and want to get the right one. TA Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 5, 2008 Share Posted November 5, 2008 Have you got the part # ?? as i am interested and want to get the right one.TA Yep, It's ESR2297. Taken from the tech archive thread on how to replace it. clicky Pete. Quote Link to comment Share on other sites More sharing options...
filthy Posted November 8, 2008 Share Posted November 8, 2008 Yep, It's ESR2297.Taken from the tech archive thread on how to replace it. clicky Pete. Once you get rid of the cat, also remove the centre box & weld a piece of straight pipe in place..... She'll rumble a bit more & use less fuel & do better when you stand on the peddle. You can then tweak the injection pump & then she'll go a bit. As far as the law goes, as long as you have at least 1 silencer, the MOT guy will accept it. If you fiddle with the injection pump settings, remember / draw the settings for reference & reset the pump to original factory settings before MOT, as the smoke level will be too high. Filthy Quote Link to comment Share on other sites More sharing options...
drkwack Posted November 10, 2008 Share Posted November 10, 2008 best to change air filter to a free flow type as well to try and keep fuel/air mix right, me I went down the Twisted Performance route, intercooler,silicone pipes,stainless exhaust system air filter and pump tweak the sound would keep J Clarkson (top gear) happy and the get up and go surprises most car drivers, I am the one with the ear to ear grin when I hit the loud pedal. Quote Link to comment Share on other sites More sharing options...
filthy Posted November 11, 2008 Share Posted November 11, 2008 best to change air filter to a free flow type as well to try and keep fuel/air mix right, me I went down the Twisted Performance route, intercooler,silicone pipes,stainless exhaust system air filter and pump tweak the sound would keep J Clarkson (top gear) happy and the get up and go surprises most car drivers, I am the one with the ear to ear grin when I hit the loud pedal. I Like the loud pedal, only problem is, bits break when the volume goes up too often - bummer, cos I like the tune. Quote Link to comment Share on other sites More sharing options...
