ibexman Posted January 26, 2006 Share Posted January 26, 2006 Got abroken latch on truck cab rear window how do you get the thing off????? Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2006 Share Posted January 26, 2006 If it's a late 90/110 window the catch has 2 screws which fit from the inside & go into the outer cover, undo these & the catch should come away from the window Quote Link to comment Share on other sites More sharing options...
ibexman Posted January 26, 2006 Author Share Posted January 26, 2006 If it's a late 90/110 window the catch has 2 screws which fit from the inside & go into the outer cover, undo these & the catch should come away from the window Its a late one Ralph but no screws might be pressed on ??? Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2006 Share Posted January 26, 2006 Its a late one Ralph but no screws might be pressed on ??? looked in parts cat, but it doesn't show how the truckcab catch is attached to the window, maybe it has 2 push fit pins that grip the body of the catch, It would be very unlikely tohave screw heads outside,on my csw the rear side window catches are fitted as I mentioned above. Quote Link to comment Share on other sites More sharing options...
