TheRecklessEngineer Posted November 21, 2008 Share Posted November 21, 2008 I lent my Disco to the parental unit for the summer, and very kindly they got it through the MOT in return. This involved fitting new tyres, a new steering joint and the garage that did both of these also did the tracking. All well and good, except it now has a liking for veering off to the left. I need to drive with a constant turn to the right to make it go in a straight line. I've also noticed that the O/S front spring has sagged by about 1/2" giving the disco a noticable list to the right. I got the tape measure out to check if everything is in a straight line - the tracking appears to be spot on, however the front axle seems to be pushed forwards about 10mm on the off side. So it seems that the hedge homing instinct is due to the axle being wonky. Is this likely to be due to the 1/2" sag in the suspension? As far as I can see, as the axle and the chassis are closer together, the radius arm is going to push the axle forward a bit. Is my thinking correct or is the answer something much more simple? Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted November 21, 2008 Share Posted November 21, 2008 I wouldnt of thought that just 1/2" of sag would be enough to move the axle 10mm! Ive driven a 1994 rrc with a fairly substansial list to the drivers side, drove spot on though. New set of springs fitted and apart from sitting correctly it drives exactly the same. Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted November 21, 2008 Share Posted November 21, 2008 Maybe the steering wheel position was disturbed & now the straight ahead position is off & where you normally & instinctively would have had a slight pressure on to the right, you now don't. It's easy to do by adjusting the track rod with the road wheels locked in the centre position, as it moves the drop arm & in turn the steering wheel rotation. Quote Link to comment Share on other sites More sharing options...
88inchthing Posted November 21, 2008 Share Posted November 21, 2008 Hi Mate If the tyres are new try swapping them side to side. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 21, 2008 Author Share Posted November 21, 2008 Thanks for the replies. I've tried swapping the tyres side to side, and no difference. The steering wheel is dead straight - or rather, if I let the wheel self-center then it ends up straight. However, if I let it self center on the road, then I end up in the ditch - hence the need to constantly steer right to go in a straight line. It did sound to me like 10mm was a little much for only 1/2" of sag. Ill jack the chassis up on the OS so both sides are level, then ill measure again. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted November 21, 2008 Share Posted November 21, 2008 I suspect that either the garage have replaced a radius arm bush wrongly or mum/dad have had a little bump. Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted November 21, 2008 Share Posted November 21, 2008 From what I have read, most Discoverys have a 1" height difference in the front end but I can't recall now which way. Soz. Quote Link to comment Share on other sites More sharing options...
