TheRecklessEngineer Posted November 28, 2008 Share Posted November 28, 2008 As the title really.... Seems my disco was put together with the last of the parts in the bin, and has an MPI crossmember. The mounts are in need of changing and no one seems to be able to get MPI mounts. If I can get my mits on a TDi crossmember then I can use TDi mounts... edit: A thought has just occured to me - are the gearbox to mount brackets different for an MPI? Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 28, 2008 Share Posted November 28, 2008 I am breaking a 300 auto disco and the crossmember is still there , Its collect only or forum relay im afraid . from Sunny Bristol in the glorious south west of England . Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 28, 2008 Author Share Posted November 28, 2008 PM sent... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 28, 2008 Share Posted November 28, 2008 Looking through microcat, it shows the MPI brackets: #1 is/was NTC9424, but now removed from service. #5 is NTC9425 The above are the type that (look like) they mount onto the crossmember. However, also listed are some other mounts, as per a V8 manual, where they bolt onto the chassis side rails (i suppose, therefore meaning it didn't matter what crossmember you had: RH mount (for 2.0mpi) is ANR2898, which is the same as the Tdi LH mount (for 2.0mpi) is ANR3225, also the same as Tdi Crossmembers are as shown: #10 was NTC6285 up to VIN JA034313 where it became NTC7557 (from VIN KA034314 onwards) (£136! ) shown for Tdi #2 is NRC7768 for V8 twin carb (£143!) #3 (was NTC5031 and ANR3246 both removed from service) but now ANR2278 for Tdi manual (£91) #4 NTC9420 2.0mpi £136 Don't know if that helps or hinders at all! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 28, 2008 Author Share Posted November 28, 2008 Hmmmm...that's quite interesting. The first piccie you posted is definitely the arrangement I have, with #4 crossmember. Looks like I need the gearbox to mount brackets too. Anyone know if the TDi auto gearbox to mount brackets are the same as the manual version? Quote Link to comment Share on other sites More sharing options...
doda456 Posted November 28, 2008 Share Posted November 28, 2008 I have a 200tdi cross member sat spare in Salisbury, Dont know if its any good, but its there want it. Dan Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 28, 2008 Share Posted November 28, 2008 Anyone know if the TDi auto gearbox to mount brackets are the same as the manual version? Auto mountings: #5 = ANR3225 £13.44 #2 = ANR2898 £2.68 And exactly the same for the R380 manual. B) B) but totally different for the LT77 Quote Link to comment Share on other sites More sharing options...
Ian M Posted November 28, 2008 Share Posted November 28, 2008 i have a 300tdi manual gearbox cross memeber, and im probably coming down to watch 4x4adventures challenge next saturday if thats any good to you? so i could pass it onto someone? Ian Quote Link to comment Share on other sites More sharing options...
JST Posted November 28, 2008 Share Posted November 28, 2008 Hmmmm...that's quite interesting. The first piccie you posted is definitely the arrangement I have, with #4 crossmember.Looks like I need the gearbox to mount brackets too. Anyone know if the TDi auto gearbox to mount brackets are the same as the manual version? yes they are the same and if yours are the same as jamies pic one then they are std mounts, just been through this fitting an auto in my 300tdi chassis with 300 tdi crossmember. long brakcet off the G box and short one off the T box IIRC. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 28, 2008 Author Share Posted November 28, 2008 Well, now I'm totally confused. The last piccie from Diesel jim of the auto crossmember and mountings looks exactly like the MPI mounts and crossmember, and exactly what is under my truck... Can anyone shed any light on this? Worth trying auto mounts? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 29, 2008 Share Posted November 29, 2008 Well, now I'm totally confused. The last piccie from Diesel jim of the auto crossmember and mountings looks exactly like the MPI mounts and crossmember, and exactly what is under my truck...Can anyone shed any light on this? Worth trying auto mounts? Mind you... don't always trust microcat to show an exact picture of the part in question..... just to confuse you more Quote Link to comment Share on other sites More sharing options...
JST Posted November 29, 2008 Share Posted November 29, 2008 why dont you phone/emial/PM Dave Ashcroft for a definate Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 2, 2008 Author Share Posted December 2, 2008 Found the right ones - the part number says they are for an auto, but they fit, so not complaining! Thanks for all your help. Quote Link to comment Share on other sites More sharing options...
