MickS Posted December 2, 2008 Share Posted December 2, 2008 Hi I lost the above the other night, (hazards work OK) changed the fuse,still blowing. Noticed that the rear wiper blade is stuck in the upright position(not its normal home). Thought I would ask for advice before I start disconnecting things, I'll probably start at the rear wiper. Any advice would be appreciated, don't want to spend hours in the cold sorting it out. Oh my baby is a Def 300tdi 110. Any help appreciated,carp at electrics. Thanks Mick Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2008 Share Posted December 2, 2008 the rear wiper is probably stuck because the shaft is partially seized, take the motor off & get some Plusgas or 3 in 1 oil down the shaft, you can connect it electrically & run it out of the door, mine did a similar thing & popped the fuse before I sorted it. Quote Link to comment Share on other sites More sharing options...
MickS Posted December 3, 2008 Author Share Posted December 3, 2008 the rear wiper is probably stuck because the shaft is partially seized, take the motor off & get some Plusgas or 3 in 1 oil down the shaft, you can connect it electrically & run it out of the door, mine did a similar thing & popped the fuse before I sorted it. Thanks for the advice, checked the wiring etc... Then I found out that the spare fuse, I had tried was already blown. Previous owner had kindly put a blown fuse in the spares tray. Everything working OK after 1/2 hour freezing my nuts off last night. Cheers Mick Quote Link to comment Share on other sites More sharing options...
western Posted December 3, 2008 Share Posted December 3, 2008 previous owners don't you just love 'em. good to read it's sorted now Quote Link to comment Share on other sites More sharing options...
landmannnn Posted December 3, 2008 Share Posted December 3, 2008 the rear wiper blade is stuck in the upright position(not its normal home). Disagree, the normal position for a defender rear wiper is "where it has seized" :lol: :lol: Quote Link to comment Share on other sites More sharing options...
western Posted December 3, 2008 Share Posted December 3, 2008 mine must be A1 then as it works really well. Quote Link to comment Share on other sites More sharing options...
