mad_pete Posted December 3, 2008 Share Posted December 3, 2008 Seeing as all the idle valves on ebay seem to come "naked" I was hoping someone could give me a rough idea of required plumbing and connectors to get this to fly with MS. Is it as easy as cutting existing hoses or do I need to get creative with a parts box ? All help gratefully received Quote Link to comment Share on other sites More sharing options...
steve_d Posted December 3, 2008 Share Posted December 3, 2008 I take it you don't want to spend a morning at the breakers where you could get yourself a valve and a fist full of hose in various shapes and sizes. You can cut off a connector when you retrieve a valve or if you buy a valve on the bay then I have some new connectors along with the terminals and seal grommets. Steve Quote Link to comment Share on other sites More sharing options...
mad_pete Posted December 3, 2008 Author Share Posted December 3, 2008 My plan for the last 3 months has been to get down a scrappy and get a valve but I never seem to actually go. So I thought I would try plan b ebay with a bit of handy advice from the wise ones on the forum. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 3, 2008 Share Posted December 3, 2008 OK You need 2x hoses I spent Ferkin hours and hours working out where and how, this is the result of what I would suggest 3.5 Flapper, - there is a hose 'S' shaped that goes from the air rail to the extra air vlave on the front of the inlet manifold, its bigger one end than the other, this fits a treat on the pipe into the plenum and the other end into the PWM bout 5 / 6 inches long maybe The other hose you need is from a Volvo 740 Turbo, long hose - and has a 180 degree bend at the end, this goes long end to the PWM and the 180 degree cvut off at an angle to fit the back of you plenum say 12 " longish You need shaped pipes, straight bendy bits are not going to do it for you HTH Nige Quote Link to comment Share on other sites More sharing options...
mad_pete Posted December 3, 2008 Author Share Posted December 3, 2008 Thanks Nige I thought it might be a bit like that. Quote Link to comment Share on other sites More sharing options...
